I'm trying to sort out some engine/automatic transmission issues and cannot find answers in my web/forum searches.  The engine is a recently overhauled 289 which had a R1 camshaft and new valve springs installed.  The engine was also bored .060 .  The prior owner had the work done.  So I have some questions.
1. Will the camshaft require a higher idle speed over the stock 550 RPM? Idle seems rough at that RPM.
2. Will it lower the engine vacuum? Currently vacuum is about 15-16. My other 289s both run at about 20. I can not find any vacuum leaks.
3. Will the valve lash need to be changed from the stock settings? I saw reference to altered settings on a post during my searches.
4. Any other pertinent information?
I believe I have transmission issues but want to eliminate the engine as a cause.
Thank you.
Thank you.
