Okay, I am finaly begining to change the clutch on my '63 plain jane Lark. It has a three speed with overdrive. to begin, I would like to know the correct way to remove the dip stick tube as I have to remove the starter as I proceed with the project. My shop manual says remove the tube. Any help will be appreciated. Thanks, Arnie
proper way to remove oil dip stick tube
Assuming it's a six cylinder, since the dipstick tube doesn't get in the way of the starter on the V8's, look for a wire spring clip, snapped under the bearing housing on the end of the starter. It holds the dipstick in place. The other end is formed in a circle threaded over the dipstick tube, and pushes the flange on the tube against the block. Snap the clip free of the starter with a screwdriver, and the dipstick tube should pull right out, easy as pie. Please clean the area first, so dirt can't fall in the hole, and find a rubber or plastic plug to place in the hole to keep dirt out of the oil pan.Gord Richmond, within Weasel range of the Alberta Badlands
(I know it is a different year, but...)
I pulled the oil fill/disptick tube out of the 6 cyl engine in my 2R10 with a Vice Grip slide hammer.
Worked OK. Popped right out.
Pulled a brand X dipstick out the same way, but pushed the back end of a drill bit into the tube hole
to keep the Vice-Grip from crushing the tube.
(Just make sure everything is unbolted like Gord said)HTIH (Hope The Info Helps)
