Need some guidance- Just finished installing the top inner rubber bushings on DOC, a '63 Hawk. The bushings are firmly seated to the rounded shoulder (per the Shop Manual instructions). However, part of the bare spindle is showing -about a total of 1/4 inch. In other words, the spindle/shaft can move sideways a total of 1/4". I do not recall if the same space was present at disassembly (there was so much paint and crud it would not have been obvious). Note-The lower bushings seated right up against the lower shaft shoulder, so I am aware what it would look like. Also, the installation process was repeated without notable movement (maybe .010 or .015" additional).
In comparing the length of the new to the old bushings, all dimensions agreed (overall length of the inner small diameter steel tube, length of the large outer tube and the length from the outer flange to the shoulder. What am I missing?
Has any one in Stude' Land replaced the upper inner bushings with the same results?
As always Thanks for Every Ones Ongoing Help,
PaulTK
PaulTK
