Changing Valve guide rubber seals on 170 OHV 6 cylinder cars
  • Engine: Changing Valve guide rubber seals on 170 OHV 6 cylinder cars
    Hi blokes,
    I recently picked up two 6 cylinder cars from Belgium. A 62 and a 64
    Both low milage and very original and ex a genuine Studebaker dealer. I have no experience with these motors at all.
    I had the Hawk up and running again for the first time in at least 10 years last weekend and the motor is a little smokey and I can imagine that the valve guide rubber seals have become brittle with age.
    Can I change them out the same way I would do it on a V8 by removing the rocker arm and injecting compressed air into the cylinder to keep the valves up to change the rubber seal over ???
    Also, is that rubber seal the same as the one in a V8 head as I have plenty of them around here that I can use?
    Thanks for your help
    Greg
    Greg Diffen
    Editor Studebaker Owners Club UK magazine
    Australian Stude guy living in Warwick, United Kingdom
    1933 St Regis Brougham Model 56 delivered new in the Netherlands
    1937 Dictator sedan Australian Body by TJ Richards RHC
    1937 Packard Super 8 Limousine UK delivered RHC
    1939 Packard Super 8 Seven Passenger sedan monster UK delivered RHC
    1939 Commander Cabriolet by Lagenthal of Switzerland
    1963 Lark Daytona Hardtop
    1988 Avanti Convertible
    Yes Greg, you can do it the same way (you'll notice the springs are not of the strong type). The seals are the same on all engines. I'd be cautious with old NOS ones beacause they can get brittle. When you have the rocker arm shaft out of the engine, I advise you to get its two plugs out and thouroughly clean it. You'll be amazed at what you find there.
      Hi Christophe,
      thanks.
      Greg
      Greg Diffen
