To All:
I am now in the process of reassembling the Studebaker 259 engine from my 1957 Commander Station Wagon. The block and Heads were recently returned from by a local racing shop that did all the machining and cleaning.
In reviewing the Shop Manual, I found a paragraph that stated that for an engine overhaul, all the oil galleries need to be purged and cleaned completely. The galleries included the oil returns which include the two (2) rear dowel pins that align the head to the block. With my engine on the assembly stand, I probed the first dowel with a piece of stranded wire. I pulled it out only to find carbon, burnt oil and metal chips. The second dowel was just as bad. For the next hour, using various screw drivers, drill bits, wire and suction from a shop vac, I managed to clean both returns. These returns are also described in the chapter defining how the lubrication system is designed and functions.
I pass this story along to all so that in your engine building efforts, you don't miss this small but critical detail. Had I not found that paragraph, I would have contaminated (metal chips) a newly machined engine and in all probability, damaged new bearings, pistons and cylinders. I called the shop and informed the owner of what I had found. He was grateful for the information and that I didn't chew him a new one.
Dave W
Dave W
