259 Cracked Exhaust Manifold
  • Exhaust: 259 Cracked Exhaust Manifold
    One of the flange ears on my exhaust manifold (where the exhaust pipe bolts up) is broken off. Is there any problem driving the car with the manifold broken. It obviously sounds like crap but we have a local car show coming up before I am going to get my replacement manifold.
    Wayne
    "Trying to shed my CASO ways"
    It should not have any ill effects on the engine, but I would look to see that it is not blowing a stream of hot exhaust toward anything flammable or that could be damaged by the heat. A temporary fix could be as simple as clamping a piece of tin or aluminum around it with a hose clamp. Good Luck!
      My 50 Commander exhaust manifold cracked and threw flames at the firewall. Since the car had no Climatizer, the flames hit the cardboard disk where the heater motor would go, igniting the stuffing behind the firewall in the passenger compartment. There I was, late at night, in my white disco outfit, by the side of the road, pulling out the stuffing and stomping it out. After all, it was 1974 in San Francisco.
      Make sure your car does not catch on fire.
        "There I was, late at night, in my white disco outfit, by the side of the road, pulling out the stuffing and stomping it out. After all, it was 1974 in San Francisco. "
        Where was Youtube then?!? I'd love to have seen that a video that!
          The crowd watching was amused, too. Much more so than I was at the time.
            I think we have some light weight aluminum flashing laying around. I might try devising a shroud around it. There is nothing around it to catch fire but it might prevent smutting up the paint on the engine and inner fender.
            Roy, I have an image in my head of you channeling your inner John Travolta putting that fire out.
            Wayne
              exhaust manifold
              I have manafolds for a 60 Lark
                You might try some exhaust manifold epoxy like Quicksteel or JB Weld. I have repaired a cracked manifold this way and didn't have to replace the manifold at all.
                  I applied some Quicksteel patch yesterday and ran the car today. Seems to have helped considerably. With one of the ears broken I am still getting some leaking around manifold to pipe flange but overall the leak is much less than it was. It will get me to the show this weekend. My replacement manifold should be back from jet hot next week.
                  Wayne
