SBC with four speed automatic. You can't get performance any cheaper and the motor mounts are available from Stude parts dealers as Studebaker installed them in 65/66. It will take weight off the front end and handle better. Don't fool with trying to adapt to the original trans just upgrade to an overdrive automatic 700/200 type. You then have a driveable setup that you can build to any power level you want and don't need to wire a computer.
If you want to go all the way with a computer system, Find a newer LS/auto setup. Motor mount adapters are cheap that will adapt this engine to the OEM Stude/Chevy mounts. In any case there will be some mods to the rear trans mount crossmember but they are minor.
The trans tunnel may need a smack or two but there nothing easier to swap than the Chevy small block.
