GT Hawk dies after driving it for 60 minutes or more
Had a similair event on a long trip a few years ago. Noticed a pssst when opened gas cap. It was supposed to be vented but obviously wasn't. So we walked to the hardware store and bought a wonderful little Rockwell battery powered drill and a small bit. Drilled a tiny hole and no more trouble. A coil will usually heat up after just a few minutes
Originally posted by Geohawk63 View PostApparently my distributor is not from a 63 Hawk. Would that affect what I order as far as a new coil? Definitely the points from a 63 do not work with my distributor. Should i just replace everything with the proper year for my car?
You have no idea if the replacement parts are good, or if you have hooked them up or assembled properly.
The proper thing to do is trouble shoot to determine the actual source of the problem, not just throw parts at it.
Remember that the car is currently running, but conks out when something gets too hot, or the gas tank gets under vacuum. Figure out what that "something" is and replace it. Just it. Not everything else.Last edited by RadioRoy; 09-01-2019, 03:11 PM.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
Yes, it's a good idea to replace the points & condenser at the same time, especially since you are already replacing the coil. It's also a good time to disassemble the distributor, inspect, clean, lube and reassemble. Especially if you wind up removing it anyway. Be sure to test the vacuum advance while you are at it, whether or not you remove the distributor.Last edited by JoeHall; 09-01-2019, 03:45 PM.
