I changed wheels on the '51 2R5 truck to a wider GM 15" rim. This required changing to a 13/16" hex lug nut. The right side was no problem, but the left (LH thread) seemed to be unavailable, I was about ready to change the studs to RH when I finally found the LH nuts. I thought that I would pass this along to anyone with a similar issue.
Left Hand 13/16" Hex Lug Nuts
Originally posted by jpepper View PostThat should be a somewhat common nut as it was used on Pontiacs and Oldsmobiles into the 60'sJim Bradley
Lake Monticello, VA
'78 Avanti II
Originally posted by StudeRich View PostNAPA has them in 13/16" LH & RH For Chrysler and Ford Products.
This is what I found:
L/H lug nuts for the left rear wheel of 1967/79 F350: 9/16" -18 x 21/32" long.
F350 right/left front and right rear use R/H lug nuts.
The Stude. Studs and Nuts are 1/2 X20 and the Nuts have a 13/16" Wrench Size.
But Dorman/NAPA Nuts are very generic for GM, MoPar and I don't know why they would not be Ford, they fit and are required on the Ford Car Wheels.StudeRich
Originally posted by StudeRich View PostThe Stude. Studs and Nuts are 1/2 X20 and the Nuts have a 13/16" Wrench Size.Jim Bradley
Lake Monticello, VA
'78 Avanti II
Originally posted by Rerun View PostNo, the original nuts are 1/2-20 with a 3/4" hex. A 13/16" hex works better with the GM wheels./Cut/
Sorry, but I was answering Bill in Post #8, he needed to know that the reason he can't find these Nuts in his Ford Truck Catalogs is Studebaker used 1/2" X20 Studs & Nuts like Ford CARS, not 9/16 X18.Last edited by StudeRich; 08-17-2019, 11:00 PM.StudeRich
Originally posted by StudeRich View PostOf course they are, I thought we were talking about the REPLACEMENT Nuts for our Studes.
But cars never had a left hand lug nut, only F350 had these and only on the left rear wheel. F350's used larger lug nuts.
