Results 1 to 7 of 7
Thread: Anyone install a pre-1956 bed on a Champ pickup?
    Silver Hawk Member Milaca's Avatar
    Apr 2005
    Milaca, Minnesota, USA.
    6,128
    I may be buying a shortbed from a 1951 Studebaker from a friend, and am wondering what it would take to make it work on a Champ.
    Will original width tires clear the fenders or would it require a different wheel backspacing to locate the tires inward for fender clearance?
    Thank you,
    Brent
    In the middle of MinneSTUDEa.
    Jul 2006
    Culleoka,Tn
    758
    It's the same frame through 62. 63/64 Changes were made to steering, brakes, front springs. Other than dat I thinks it's da same. Not that much to mounting, you'd think there'd be more but not.
    Kim
    Dec 2005
    Fresno, California, USA.
    3,861
    Keep in mind: the 51 bed is narrower than the post 55(?) beds.
    KURTRUK
    Apr 2012
    princeton mn
    3,078
    Brent being the frames are the same I would think the only issue you may run into are some frame mounts.
    Silver Hawk Member
    Jun 2006
    Spokane, WA, USA.
    8,193
    Thoughts:
    Which model Champ? The 1/2t and 3/4t are slightly different.
    Are the wheels and tires original widths?
    Same but different; I installed a Champ 3/4t Dana 60 under my '55E12. So in that instance, the wider rear axle fit under the narrow bed. The original Timken rear axle was slightly narrower than the front axle and the Dana 60 is wider than the front tread.
    Silver Hawk Member
    Sep 2005
    Washington, DC, USA.
    6,179
    The difference in half-ton rear tread (which I believe is the distance between the center lines of the tires) is only a bit more than an inch. 59 9/16" on the 49-55 and 60 13/16" on the 56 and later.
    Dec 2011
    Middle Tennessee
    1,775
    I'll bet it'll look gooooood on there.
