Hi,
I could do with some suggestions to get my vacuum wiper motor working on my 2R6-2 Pickup.
Here's what I've done so far....
I removed the original wiper motor (not working) and sourced replacement wiper motor (working).
I checked the replacement wiper motor by hooking it up to the vacuum pipe and watched the actuating arms feverishly working back and forth, so a good start
I bolted the wiper motor in place, performed by best contortionist moves (ought to have been in the circus) to press on the wiper arms on to the actuating spindles, followed by working blind to hook a brand new spring on to the spindles. Using my nifty gadget, mirror with small LED light to check the spring was seated okay, I was feeling relieved and fully expectant of wiper blades to do their 'stuff.' However, I was disappointed to see nothing happen.
Moved across to the passenger side to double check operation of turning wiper switch was turning / pulling the motor on and off, check, working fine.
I bought new grommets, but have yet to fit to the wiper arms. My view was if the wipers operated, best hang on to the grommets for when / if they might fail.
Would this be the cause of the wiper blades not working?
I noted the existing grommets on the wiper arms have worn into a hexagonal shape, which is much different to the circular shape of the new grommets and presume the difference is shape is due to original grommets being in place almost 70 years.
I also note the driver's side wiper arm cuts really close to the heater matrix for which my heater matrix chimney (?) has had a knock or two in the past.
Any suggestions greatly received with thanks... and some accompanying photos of progress to date,
Richard
Last photo is looking from the driver's wing across to the passenger side, driver's wiper arm and motor in view under the hood
