I have a 1960 Lark VI wagon, 74K, owned it for 6 years, it has always had the oil pressure light come on after starting,
and would go out at 1000rpm.
After it sitting for 6 months, and I've restarted it, it runs fine, but now I notice that the oil light comes on and doesn't go
completely out until about 2000 rpm and it's faint from 1500 rpm until then. Those rpms are basically.....
I have replace the oil pressure sender recently, it's new. I have not checked or touched the oil pressure relief valve since
I've had it due to its location and that being a PITA.
Is messing with that something that might help boost the oil pressure? I don't have an oil pressure testing gauge, is that
something I can get from NAPA or Harbor Freight and make the effort to see what numbers the testing gauge will tell me?
What else should I be doing at this point?
Thank you.
Thank you.
