Hello I will be installing a new brake switch on my 55 Champion this afternoon. The only reference to this in the manual is to bleed the front brakes afterwards. My question is when I remove the old switch should I expect free flow of brake fluid as when open a bleeder screw or is there some some sort of one way valve behind the switch that prevents this.
Also is bleeding the front brakes only as recommended sufficient or is there need to do full four wheel bleed. Thank you for any pointers.
