Gents,
I am experiencing severe lugging of engine when starting from a stop only when the engine is up to full operating temperature. I have a 1963 R1 with carter 4 bbl that I recently rebuilt. I have also done a tune up but discovered that I do not have the original Avanti dual point distributor but instead a single point distributor from a 1960 Lark. However in the past, the car ran fine and did not lug with this distributor. One question I have is should I set the point gap and dwell to those spec'd for the 1960 Lark distributor or should I set the timing etc. as per the Avanti specs? Timing degrees are both 4 Percent; the major difference is the Dwell angle range for the Lark is 28-34 and for the Original Avanti 27-31. I set it at 27. I set rpm around 700 and have tried higher rpms but still lugging. Not sure if the timing set up is the cause of my engine lugging. The only other variable is that I installed a new electric fuel pump rated for 4-7 psi but it seems to be getting plenty of fuel and I replaced the rubber hoses and gas filter. When car was running well it also had an electric pump. Any suggestions as to what I should concentrate on would be appreciated!
