I’ve never been mechanical so most of my questions are remedial to say the least. So here’s another one. I’m putting points in a 170 6 cylinder and there’s 3 wires that I don’t know where they go. Ones looks like a ground and one is coming from the condenser. Third one is a light brown one screwed into the housing
Installing points in a 170 six - wiring
The Condensor Wire INSIDE the Distributor, connects to the POINTS where the Wire through the Dist. Case to the Coil (-) Negative Terminal on a 12 Volt Neg. Ground Car, [or the (+) Terminal on a 6 Volt Positive Ground Car] goes.
The probably Brown, cloth covered wire is the Breaker Plate to Case Ground.
What Year, Model and Car or Truck are we working on?StudeRich
Title changed to better description of the advice sought, for future searchers.
