Results 1 to 11 of 11
Thread: still no brake lights
    Aug 2005
    , , USA.
    267
    The brake lights have not worked on my '52 Commander since I got it, recently. If I unplug the wires at the brake light switch and stick them together, the lights work. The switch appeared to be the original, old anyway, so I replaced it. Still, no brake lights. The brakes feel like they might need bleeding again, though a complete brake replacement was done before I got the car. That is my next plan, to bleed the brakes again and see if that fixes it, I hope.
    thom
    1,425
    Thom, make sure the junction block is clear. I have seen them get crudded up pretty bad. also that new switch could be bad. remove switch and have a helper LIGHTLY press brake pedal,a finger over B L port will keep most air out. Luck Doofus
    Sacramento, CA, USA.
    5,500
    Try a brake light switch from a motorcycle. Harley I think. They require less pressure to activate.
    sals54
    Puget Sound, , USA.
    4,328
    Test for power out of the switch with voltmeter or test light when brake pedal is pushed. If you have power then, suspect the turn signal switch.
    Nov 2013
    Goldendale WA
    213
    Just got one for my 49 Champion yesterday at Federated Auto Parts, Standard SLS27. Around $11, 1/8 pipe thread, screwed right in. If your quick you may only lose few drops of fluid . Works ok. not wired through turn signals on 49.
    Aug 2005
    , , USA.
    267
    Studebaker International is my usual go-to for parts but they don't list a turn signal switch for my '52. Wonder if I can disassemble and clean it and fix it? Anybody tried it?
    I know the feed wire to the switch is "hot" now, because if I cross the wires the brake lights come on, but I don't know what is happening when the brake pedal is pushed.
    thom
    Speedster Member 3rdGenStude's Avatar
    Nov 2006
    Suttons Bay, MI, USA.
    429
    Like Sals54 said, go to a Harley-Davidson dealer and get a switch. It worked great in my Hawk.
    Paul
    I finally have a Stude I can drive! (sort of)
    1962 GT Hawk, 4 speed, a/c
    Aug 2005
    , , USA.
    267
    I can only imagine what a Harley switch would cost, if it's like every other Harley part I've known. And if the problem is in the turn signal switch, the Harley switch won't solve the problem anyway.
    thom
    4,909
    I bought mine at NAPA for about $12, and it comes with a 2 year warranty.
    29,662
    Your problem is very likely as simple as cleaning out all the green corrosion INSIDE of those Wire Terminals, we had one yesterday on an Avanti at the Special Avanti Event that when you pressed on the terminals you would get contact, but when released, nothing.
    They HAVE to be clean, dry and tight, also try crimping the Female Bullets a little tighter.
    Middle Tennessee
    1,836
    Dont you know? H-D means Hundred Dollars......
