Results 1 to 11 of 11
Thread: '64 Champ Questions
    Speedster Member Jeb's Avatar
    Jun 2011
    Salcha, Alaska
    147
    '64 Champ Questions
    My son is looking at Champ trucks and found one for sale in Washington. It's a "64 8E7. It has a 122 inch wheel base and a custom flatbed instead of a standard bed. What does the 8E7 designate? Does the wheelbase indicate a long bed? Would my friends extra Champ step side bed fit this truck? What should we look out for when looking at Champs? The rig has a clean looking 259 and the $5500 price seems to be in line with the overall condition but our limited knowledge/experience is making my boy wary.
    Millington Tn
    290
    Check thread labeled Champ pickup for sale, Hood Canal area of WA
    Jun 2011
    Salcha, Alaska
    147
    Quote Originally Posted by 70Avanti2 View Post
    The craigslist ad was removed. The truck must have sold.
    Jun 2011
    Salcha, Alaska
    147
    The truck my son found is the orange one from the post by StudeRich. https://seattle.craigslist.org/kit/c...319454056.html. My friend has a Champ step side bed and we wondered if it would fit the 122 inch wheelbase. Is there a restoration/repair shop in that area who could repair the steering for us before we brought it north? We would like to get whatever he buys in shape before we bring it north. We have to do all our own work here as mechanics with correct knowledge are as rare as hen's teeth in the interior.
    6,232
    8E7 means/meant 1963/64 half-ton Champ with a V8. Could have been had with either a 112" or 122" WB.
    Jun 2011
    Salcha, Alaska
    147
    Thank you. Do the numbers designate trim code too? We wonder how much of the correct trim is still present on the truck.
    Millington Tn
    290
    Post #2. In the thread its the same truck. Just a two year time span
    Kentucky Bluegrass
    3,216
    The body tag will be on the cowl above where the heater air inlet goes into the cab. It does not have the sliding rear glass, but they could be eliminated if the buyer wanted.
    Place to look for problems would be the floor area below the a pillar. This is where the front of the body bolts to a frame outrigger and it is where all the moisture runs when the floorboard gets wet. I would also look to see how firm the clutch pivot is - these trucks were notorious for that breaking and Studebaker even came out with a service bulletin to tell dealers how to fix the problem.
    Once you guys have it in your garage, please add photos and information to the online registry - there is always room for one more.
    Good luck.
    6,232
    The body tag will tell you whether it's standard (T4) or deluxe (T6) trim. Both the narrow and wide beds came in lengths of 6.5' (112" WB) and 8' (122" WB).
    Skip Lackie
    29,584
    Yes you can install the 8 Foot narrow bed as used on 1956 to Early 1961 Stude. Trucks.
    However, the '49 to '55's were narrower than '56, that might be a small problem.
    It sure would be too bad to remove that nice polished Diamond Plate Aluminum Flatbed though.
    But I understand, it's a problem keeping things IN or ON those!
    There is a good Studebaker Mechanic I know; Brian Curtis in Davenport & Harrington, Eastern WA near Spokane, and MAYBE he or Jack Vines here on the Forum MIGHT want to take it on, you would need to ask.
    Jun 2011
    Salcha, Alaska
    147
    Thanks for all the information. I found the old pictures of the truck when it was white. It looks like a bit of work has been done. We'll call the owner tonight and then bother Brian and Jack. If my boy flies down to see the truck I might beg Washington members to accompany him. I'll post our progress tomorrow. BTW, the flatbed does look nice.
