64 Avanti PW
  • Electrical: 64 Avanti PW
    What amperage does the power window motor draw on my 64 Avanti?
    They pull a lot of amps. The wiring harness for the motors use 10 gauge wiring. I used to see the ammeter swing to -25 - -30 amps if the window was raised with the engine off. You should keep the regulators maintained as well as the gear on top of the motor. Early Avanti doors were a bit on the weak side and panel flex is an issue. Slow operation generally means something needs lubrication. It can be a bent regulator also.
    64 GT Hawk (K7)
    1970 Avanti (R3)
      Thanks Bob, I feel it's not the motor and something dragging. I will dive in to procedure. Steve
        Bob's site has lot's of info on these poorly designed power windows. Here's the link-probably more infor there than any of us can post here. http://www.studebaker-info.org/rjtechoct2014p1.html
        and here: http://forum.studebakerdriversclub.c...nti-Door-issue
        Have fun!
