Hill Holder 1951 studebaker
  • Brakes: Hill Holder 1951 studebaker
    Hi!
    I have a 1951 Studebaker with hill holder, it is of the electric type, there sits a switch on the bulkhead, which is activated by the accelerator.
    I am very unsure of Capital I should connect this up, from switching on the bulkhead there is a line out from the hill holder is the 2 wires out.
    Should there be any kind of hold Reel on the circuit?
    Someone who can help me? For little or no information on the internet about this kind of hill holder.
ID:	1707765 Her is the switch on the bulkhead
      I did not know about an electric hill holder. Can someone provide some educational information on this. Here it is only 7 AM and I have learned something new today.
      Perry
      \'50 Business Champion
      \'50 Starlight Champion
      \'60 Lark Convertible,
      \'63 GT R1,
      \'67 Triumph TR4A
        It is not a "hill holder" as applied to vehicles of the 40's, 50s and 60's as they were all purely mechanical. Perhaps a search on "line lock" would be more beneficial, these solenoid controlled units are a modern attempts to do the same thing, and it appears to be one such unit. As to brand wiring and location of the switch, any relays etc., would be manufacturer specific. One such example is here: http://www.jegs.com/i/Hurst/530/174-...FUpZhgodnoEImw
          On cars with the Detroit gear automatic there is a solenoid in the rear hydraulic brake circuit that locks the brake fluid for the rear brake cylinders in so the rear wheel cylinders do not release and prevent the car from moving.
          It is called an anti-creep valve.
          It releases when the gas pedal is depressed.
          I enlarged the picture of the switch.
          There are only two connections on the switch.
          It can be hooked up to either terminal,one to the ignition switch and the other one to the solenoid.
          Robert Kapteyn
            Is a "Hold Reel" something like a Fuse or Circuit Breaker maybe?
            It is applied by the Transmission Switch and the Brake Switch and RELEASED by the Accelerator Switch.
              I just disconnected the one on my 54. Works fine without it - like a modern car.
              60V-L6 - 60 Lark convertible
                As Bob explained, this is the Anti-creep on an automatic transmission equipped car; no similarity to the hill-holder with standard transmissions. The slightest touch of the accelerator releases the solenoid. Still works in my '51 after 65 years.
                '33 Rockne 10,
                '51 Commander Starlight,
                '56 Sky Hawk
                  As mentioned above, it is the "Anti Creep" developed by Studebaker to make the automatic transmissions more appealing to buyers; automatic trannys were still new to most car buyers in 1951. I've had 2 cars with this set up installed, neither one worked and I didn't miss it at all.
                  You can test it by stopping the car and slowly releasing the brake pedal, it shouldn't creep forward until the gas pedal is pressed.
                    Looks like an accident on it's way to happen. Disconnect it.
