Missing Nut
  • Body / Glass: Missing Nut
    I've got a noise that I suspect is a loose body mount or as has been suggested worn out rubber gaskets and I came across this issue while trying to figure this out .
    Just ahead of the rear wheel on the drivers there is a bolt that appears to be properly in place as per these pics:
ID:	1751248Click image for larger version
    But on the passenger side there is either a stud or bolt with no nut on it. It's in the same spot on the passenger side as on the driver's side as per these pics:
ID:	1751250Click image for larger version
    The "thumping" sound I am getting is seemingly coming from the passenger side. Anyone know what this stud/bolt's purpose is? I'm hoping this might be the cause of the noise.
    The one on the Left Side with the Hex Head on it is not a Nut, it's a Screw, maybe going into a Nutplate. They do not appear to be going vertically between the Frame and Body.
      Could they be seat belt mounting bolts without the large washer??? just a thought. checked your shocks? Doofus
        Yeah, that could be! It has seat belts. Shocks are new. That's what I thought was making all of the noise but turns out that wasn't the cause.
          Have you checked the gas tank mountings ?
          Geoff
            Geoff
            Yes I have and they seem OK. That was my first thought as that is exactly what it sounds like. It's a new gas tank but I am getting it up on a hoist on Thursday to have a better look and I will look closer at that as well. Thanks Geoff..
            Kevin
              I'm not missing, I'm on vacation
              Bez Auto Alchemy
                I don`t know if yours has the same type of mounting as my 50
                On one side of mine it has a coil spring, if it has, check that it`s not broken allowing the tank to move up and down.
                Geoff
                  Many of the "missing nut(s)" are in, or on their way to, Warwick.
                  Dan Peterson
                  Montpelier, VT
                  1960 Lark V-8 Convertible
                    Joseph R. Zeiger
                      Geoff
                      Thanks.. I'll check that..
                        Well.. if you are on vacation at this time of the year you can't be THAT nuts!
                          And probably talking to themselves.. right?
