Help identifying this master cylinder.
I found my master cylinder using the part numbers that you supplied, thank you so much. I am installing a disk brake conversion kit on my 63 cruiser and I hope that this master cylinder or a new one like it will work with them.Mike Kelly
Regional Manager
Texas
1963 Lark Cruiser
1962 GT Hawk
1965 Commander 2dr v8 auto
Originally posted by Mrkelly View PostI am installing a disk brake conversion kit on my 63 cruiser and I hope that this master cylinder or a new one like it will work with them.
The very best thing to do is to consult the company that you are purchasing the disc brake conversion from. If they are a knowledgeable bunch (ie, like Jim Turner at Turner Brake) they can advise you about what to do with your master cylinder, and recommend potential replacements that will work correctly with the conversion. If they are not a knowledgeable bunch and can't help you.......consider a different disc brake conversion.
Originally posted by Mrkelly View PostI found my master cylinder using the part numbers that you supplied, thank you so much. I am installing a disk brake conversion kit on my 63 cruiser and I hope that this master cylinder or a new one like it will work with them.
Master Cylinders for Disc Brakes always have a Larger Rear Reservoir section for the Front Disc Brakes than the Front portion for the Rear DRUM Brakes.
As Paul said, the MC 36237 will NOT work for Disc Brakes for multiple reasons.StudeRich
