White headlight toggle with ridges?
  • Electrical: White headlight toggle with ridges?
    Hello, Does anyone sell the headlight toggle switch for the 1963 Cruiser/Lark. It is white with ridges? SI only has one that is white without ridges. I would like for them to match. Thanks, Steve
    Steve Nowicki
    Davis, CA
    1963 Studebaker Cruiser
    289 V8 2bbl
    Flight-o-matic
    Twin Traction Dana 44
    Factory front power disc brakes
    Rose mist with Chestnut interior
    You can carefully remove the plastic part of the switch and exchange as required white ribbed/white smooth/black smooth.
    Your car happens to have a new '66 switch (black, smooth) installed, but take apart an old white ribbed switch and you can see how the exterior part can be easily exchanged.
      I believe that it is a rocker switch, not a toggle switch. That may help in your search.
        I have two pair of the ribbed white rocker switches from a 63 lark I parted out. There are four switches complete with wiring harness and light. Cost of mailing if interested. David
          We have N.O.S. headlamp rocker switches in stock for 1963 and later models. And we can put together a complete N.O.S. set if needed.
          Chris.
