I have a metallic thumping noise on my 62 GT that I thought was the shock that was missing it's bushing but the springs have been re-arched, a spring added and new shocks installed and the noise is still there. In the process of trying to see if any body panels are loose and making the sound I found that both front body mount bolts are loose. Not loose enough to turn by hand but close to that. Are these supposed to be torqued down to a specific torque or tightened as much as possible? I cannot find my mirror to look and see if the nut is castellated but I could not get a socket or wrench on it. Anybody know what size it is? Here are some pics of the bolt I'm talking about.
Don't think this is the cause of the noise as it seems to be coming from the rear. It sounds like a broken shock so I am surprised that wasn't the problem. I only hear it when in motion and it is not exhaust, that has been checked thoroughly. Any ideas?
Front Body Mounts
Tags: None
Originally posted by 55 56 PREZ 4D View PostCould be that the rubber pad between the mount and the frame has disintegrated and the mount is bumping against the frame.
Not quite as easy as that. Soak the bolt threads with a good rust penetrating fluid. Remove them. Then devise a way to lift the body enough to remove the old and then install the new rubber pieces. Do a search to find info on whats needed, but most people use 2" squares cut from the sides of old tires. There will be steel spacers of varying thickness. Replace them in the same locations. Don't mix them up.South Lompoc Studebaker
Originally posted by 55 56 PREZ 4D View PostNot quite as easy as that. Soak the bolt threads with a good rust penetrating fluid. Remove them. Then devise a way to lift the body enough to remove the old and then install the new rubber pieces. Do a search to find info on whats needed, but most people use 2" squares cut from the sides of old tires. There will be steel spacers of varying thickness. Replace them in the same locations. Don't mix them up.
http://www.studebakerparts.com/stude...oduct=rubbert&
This is one source.
http://www.studebakervendors.com/
You will probably find other sources here.South Lompoc Studebaker
Originally posted by 55 56 PREZ 4D View Posthttp://www.studebakerparts.com/stude...oduct=rubbert&
This is one source.
Also, and it may not apply here, be sure the bolt hasn't already "bottomed out" if it is a "blind" nut or a shouldered bolt. It looks like these have been removed before with no rust showing, so a wrong length shoulder on a bolt will "bottom out" and not let you actually tighten it past the threads, causing you to break it off trying. Just a caution.
Originally posted by karterfred88 View PostAlso, and it may not apply here, be sure the bolt hasn't already "bottomed out" if it is a "blind" nut or a shouldered bolt. It looks like these have been removed before with no rust showing, so a wrong length shoulder on a bolt will "bottom out" and not let you actually tighten it past the threads, causing you to break it off trying. Just a caution.
