I have a 1959 Studebaker Deluxe (Transtar) 1/2t short box. Serial # 4E7112. I received information from either SDC or the Museum I can't remember that this truck came originally with a 259 V8. I just got the truck back from the mechanic who did a complete overhaul. The engine now in the truck though is not a 259 but a 289. Engine serial # 7EI06I. I don't know whether the "I" are letter "i's", the # 1 or roman numeral I. It appears this engine was original to a 1963 model commercial truck probably a 1 ton or larger. Can you tell me if my assumption's correct, and any other info on this engine?
Truck Engines
I don't know if all the data are correct on this Tech Tips page of the SDC website ( http://www.studebakerdriversclub.com/tech_v8data.asp ), but it would indicate a 1963 289, as you said. And yes, the "I" is really a "1" in those engine stampings.
[img=left]http://simps.us/studebaker/misc/images/Avacar-hcsdc.gif[/img=left]
Paul Simpson
"DilloCrafter"
1955 1/2 Ton Pickup
The Red-Headed Amazon
Deep in the heart of Texas
Paul Simpson
"DilloCrafter"
1955 1/2 Ton Pickup
Interesting... to the best of my knowledge all '59 Deluxe series ([u]see I did not say Transtar!!</u>) trucks came with the 289 V8 motor (when V8 equipped)
. Only the Scotsman came with a 259 (when V8 equipped) in the 1959 model year. So, while you do not have a stock motor, it is the correct displacement for your truck. [8D]
<h5>Mark
'57 Transtar
3E-6/7-122 </h5>
Mark Hayden
'66 Commander
Zone Coordinator
Pacific Can-Am Zone
Does the engine have a oil filter mounted on the passenger side of the block? If it doesnt have a oil filter or a block off plate on that side of the block it is a mid 62 or earlier block. Block off plates were used on some later engines when customers ordered optional partial flow filters or to install in earlier trucks/cars.
My 1963 8E28 has its original 289 engine 7E2964,(on truck engines 7E denotes a standard duty 289 V8). My trucks final assembly was in October of 1962. Given Studebakers truck production rate,
its entirely possible that 7E1061 is from 1959 or maybe even earlier.
The most obvious thing is the oil filter on the right side of the block, whether its there or not.
Mark, the standard V8 for the 4E7 Deluxe is a 259 cid engine(3E*****).
Standard engines and the serial number range for them, are in the front of the trucks parts books.
Only the prefixes and a explanation of what equipment constitutes an optional or heavy duty engine are explained there.
3E38
4E2
4E28
5E13
7E7
8E7
8E12
8E28
59 Lark
etc
This is where I found (my apparently incorrect) assumption![:0] As you can see the beginning of the middle paragraph on the right column says "All V8 domestic models except the Scotsman 4E2 used the 289."[B)]
<h5>Mark
'57 Transtar
3E-6/7-122 </h5>
[img]Mark Hayden
'66 Commander
Zone Coordinator
Pacific Can-Am Zone
Maybe true... but I just checked the December '97 issue of TW that featured 4E Series Standard and Deluxe Trucks - in that article the statement is made that: "All Domestic non-fleet V8 models came standard with the 289, while Export and Scotsman models came with the 259." So, that would support the premise that the vast majority of Deluxe V8 equipped 4E trucks should have come from the factory with a 289 powerplant.
<h5>Mark
'57 Transtar
3E-6/7-122 </h5>
[img]Mark Hayden
'66 Commander
Zone Coordinator
Pacific Can-Am Zone
