vinyl top
  • Body: vinyl top
    Had interesting am. Took 64 to upholstery shop. Guy says stainless trim on rain gutter has to come off. His Abra buddy says sure he can remove it but will likely ruin it in doing so. Car is back home with top still in pickup. Is it necessary to remove the trim on the rain gutter to install the top???
    NO, do not remove that trim. They should be able to glue the top down into the rain gutter and then use a sealer to cover the raw edge. I had my 66 done that way 4 years ago and it's not shown any signs of a problem. Find another trim shop that does vinyl tops for a living, not just seats and headliners. You will need to remove the windshield and rear window to get the vinyl glued under correctly. Some say they can stuff the vinyl under the rubber, but it always comes back to haunt you somehow.
    1950 Champion Convertible
    1950 Champion 4Dr
    1955 President 2 Dr Hardtop
    1957 Thunderbird
      A "64" should not have a vinyl top. I knew of a 1965 Cruiser with a vinyl top and of course all of the Sports Sedans ('65-'66). Are you making a custom or perhaps you got the year of your car wrong?
        It is a GT Hawk
          It is a GT Hawk
          Thanks! My error. That is one combination that I hadn't thought of (thinking sedans). You just have a canopy roof.
          In any case, I always recommend against removing the drip moulding, if at all possible. Yes, the trim will most likely, but not necessarily, be ruined upon removal. If you have new/good drip rail trim on hand then I woud remove it.
          I think that I got more confused (thinking sedan) by thunderations stating that you must remove the windshield and rear glass.
            I was thinking sedan too.................OPPS.
            1950 Champion 4Dr
            1957 Thunderbird
              I had a 64 GT once upon a time.... had to remove the chrome strip that runs across the roof at the rear of the vinyl. That involves removing the head liner, at least I should have removed it to get to the threaded fasteners. Slit it instead. Dumb move. Don't remember removing the drip rail moldings though.
                Thanks. Need a new shop or dity.
                  Jeffry as said you should be able to glue and seal top at drip rail. Just be sure they do a good job sealing it all the way around. Water will not be your friend. And with time the top will start to lift up at the edge. Do you have the mldg. that runs across the back of the top? They do make universal mldgs but they wont look as nice. The tops on the Gt's where only half tops.
                    I will put a nice used roof moulding for the 1964 Hawk sports roof on eBay
                    but will offer it here first for $ 350.00.
                    Robert Kapteyn
                    815 212 2389
                      While I agree with others that these drip moulds should not be removed if it can be avoided, it is possible to do so with patience (which I don't have) and practice (which I can't afford). The lower edge needs to be gently pushed outwards from inside the car using something blunt like a flat piece of wood. And if you ever have the chance, have a close look at how the drip rail area was sealed by the Hamilton factory on 1965-66 Vinyl roof cars. They were nicely finished cars.
                      Chris.
                        .....he can remove it but will likely ruin it .......
                        In order to paint a few cars, I've removed that trim with a beer bottle opener. Never hurt it...
                        64 GT Hawk (K7)
                        1970 Avanti (R3)
