Does anybody have good advice on unsticking the throttle shafts on an AFB? Thanks.
Unsticking throttle shafts
Fuel System: Unsticking throttle shafts
1963 Champ "Stu Bludebaker"- sometimes driver
1957 Silver Hawk "Josie"- picking up the pieces after an unreliable body man let it rot for 11 years from an almost driver to a basket case
1951 Land Cruiser "Bunnie Ketcher" only 47M miles!
1951 Commander Starlight "Dale"- basket case
1947 Champion "Sally"- basket case
1941 Commander Land Cruiser "Ursula"- basket caseTags: None
Have gone down this road more times than i care to remember. if soaking in your favorite penetrant doesn't work, gentle heat on casting. if still bound up i have drilled a tiny hole through casting to throttle shaft for penetrating oil. one such project i had to do both shafts, then countersink each hole to hold more penetrant.it still survives to this day as a runner. at one time the AFB was scarce, now i've got a tub full of whole carbs and a pile of spare bits. stude and brand X as well. good thing as i needed a really small 4bbl for the 224/turbo project. built a 400cfm carb from scraps that works good. Luck Doofus
I've got the primaries unstuck on the main carburetor tonight. I'm in the beginning of getting the secondaries unstuck on the donor carb. It's been through a fire and even has a melted electric choke on it. It even has that mysterious big jumbo third idle screw up front. Anyway, I'm letting the Blaster soak in for another day. Can you buy Kroil in Omaha? Until then, I made some Kroil Klone with cheap ATF and acetone. Any advice on getting stuck jets out?1963 Champ "Stu Bludebaker"- sometimes driver
try to read the no's on the jet first. soft brass can be hard to deal with. a screw driver ground to fit the jet's slot is a start. if that does'nt do it go with a small easy out. if jet is undamaged , when trying screwdriver, use lot's of downward pressure on handle to keep from camming out and stripping slot. sounds like a GM carb, what number is it? i may have some bits for it. Luck Doofus
