lower outer pin
  • Steering: lower outer pin
    Can a guy use a small porta power with a duck bill end to spread the lower control arm to install the lower pin in place of using any special tools? I need to start on putting my control arms and spindles back together this next week.
    Would it be too easy to over-spread and distort the A-arms with the porta-power?
    Do the duck bills apply parallel force, or do they spread in a V shape?
    60V-L6 - 60 Lark convertible
      J-2044 special tool is only $35 from Chuck Collins in Arizona. If this breaks the bank, I believe you can rent one from him?? www.studeparts.com
        Duck bill spreads in a v shape. The tool wont break the bank but just thought why not use what I have. I may even have some other tools that will work if I look hard enough.
          A coil spring compressor would work with the clamps reversed !!!
          as would the hydraulic Duck Bill with care
          It`s not as if your trying to open it an inch !!!
          Geoff
            Even the tool made for it opens it in a V Shape. You're only moving it a few thousandths. Use what you have as long as it doesn't come loose at the most inappropriate time........and it's not in your way while you're trying to do the work.
            Dis-Use on a Car is Worse Than Mis-Use...
            1959 Studebaker Lark VIII 2DHTP
