while I was pressing the dash lights controller on my 64 cruiser all the dash lights went out,thinking it was a fuse I proceded to look for the fuse, you guessed it I could not find the fuse anyone know were it is at? thanks in advance. LEONARD
dash lights
Tags: None
There is no Fuse needed since the power has to come from the Headlight Switch so they could only Light with Parking or Head lights. Therefore the safety is the Headlight Circuit Breaker.
If you look UNDER your dash you will find the Dimmer which dims the Instrument lights when in the Low Pos. on the Instrument Light Switch, twisting that may bring them on in Dim Mode, but in High Mode if you have nothing, the Instr. Lt. Switch may need to be wiggled (switched ON and OFF) to make it operate, if not replace it.StudeRich
