Anybody know the flow rates on a 1955 WCFB vs a 1961 WCFB as found on Studebakers? Why does the later carb have the counterweight/damper on the secondary air valves?
carburetor flow rate
Don't know about CFM rates but the early ones didn't work well on transition, the air valve, like on the AFB, slows down and smoothens the change in air flow to prevent bogging. This article says that since Carter didn't publish CFM rates all the rates are guesses anyway:http://www.jalopyjournal.com/forum/t...b-tech.851851/ Probably right, as even the early AFBs on the R cars are really guesses at 625.
Try around 385 CFM according to a carter book i found. the secondary air does exactly like Karterfred88 said, when secondary butterfly's are tripped the SAV slow's down air flow and creates a depression at fuel dump tubes to get fuel moving into air stream, without SAV you had to go easy when" jumping on it". Luck Doofus
Originally posted by doofus View PostTry around 385 CFM according to a carter book i found. the secondary air does exactly like Karterfred88 said, when secondary butterfly's are tripped the SAV slow's down air flow and creates a depression at fuel dump tubes to get fuel moving into air stream, without SAV you had to go easy when" jumping on it". Luck Doofus
It is possible that someone had removed the counterweights but when looking down at the carb it looked different. No idea if an AFB made with counterweights will run without them.
Len
Chrysler used an AFB with side hung secondary venturies. I don't think they had the secondary air valve. Later on the had a similar designed AFB type crburetor called an AVS, that had the secondary air valv above the veturies like a secondary choke plat. It had an adjustable tension spring, so the cut in rate could be tailored to the individual engine flow rates. Edelbrock has this carb reproduced now, and is a better design than the original, because it has the secondry metering venturies, which the original AVS lacked.Bez Auto Alchemy
Fellas, I asked about WCFB's. I have both designs; without counter-weighted air valves and with counter-weighted air valve. The 'without' is the 'correct original' as originally installed on my 67,000 mile '55 President State Coupe. The other 'with' has the correct Studebaker throttle arm and mount for the dash pot, but I don't know what year it came from. It is missing the brass ID tag. I was curious as to whether the later carb would have a higher cfm flow rate.
Look down on the venturi at the secondary side early non SAV carbs are marked 15/16. later carbs maybe larger, i have seen non stude wcfb's marked 1 1/16 with oval secondary blades. i have 2 early non SAV carbs for an R-1 project but no id tags. Luck Doofus
