Only the '61-'64 Convertibles and '63-'66 Wagonaires' with Manual Steering have the Low Ratio, Slow and easy to turn Box, all the rest '61-'66; Standard and Power, have the slightly quicker Ratio.
Steering Column lengths, Boxes, & Wheels
Any good machine shop could re-spline the steering wheel or make an adapter for it. Might be a better way to go then splicing a steering shaft. I've walked into many machine shops with a big problem only to have them provide a simple solution based on experience and past applications.sigpic1966 Daytona (The First One)
1950 Champion Convertible
1950 Champion 4Dr
1955 President 2 Dr Hardtop
1957 Thunderbird
Originally posted by StudeRich View PostOnly the '61-'64 Convertibles and '63-'66 Wagonaires' with Manual Steering have the Low Ratio, Slow and easy to turn Box, all the rest '61-'66; Standard and Power, have the slightly quicker Ratio.-------------------
Daddy always said, if yer gonna be dumb, you gotta be tough & I\'m one tough sumbiatch!
Originally posted by thunderations View PostI've walked into many machine shops with a big problem only to have them provide a simple solution based on experience and past applications.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
I have put in a later Lark Saginaw recirculating ball steering box on a 53 Commander. No problems, used the whole shebang wiring for turnsignal and everything. All that has to be mdified it the reach rod from the pitman arm to the bellcrank. There is info on a similar conversion as done by others on Bob Johnstones excellent website. You don't have to keep the original wheel as in this article. I didn't and it was fine using the 63 column and wheel.
Bez Auto Alchemy
Originally posted by bezhawk View PostI have put in a later Lark Saginaw recirculating ball steering box on a 53 Commander. No problems, used the whole shebang wiring for turnsignal and everything. All that has to be mdified it the reach rod from the pitman arm to the bellcrank. There is info on a similar conversion as done by others on Bob Johnstones excellent website. You don't have to keep the original wheel as in this article. I didn't and it was fine using the 63 column and wheel.
http://www.studebaker-info.org/TW/tw1098/tw1098p28.html-------------------
