Well, I put the head back on and buttoned it all up.
It runs much much better although smokes a fair bit, but for the moment I`m putting that down to stuck rings as was # 3 inlet valve that needed the head pulling to correct in the first place.
As to the damper it is still way way off and even putting the spark sensor clamp of the strobe timing light on every lead the timing marks are nowhere to be seen.
So somethings amiss there.
The Dizzy is not The one listed for a 51 Champion it`s a IAT4010
I also note on page 18 in the engine section of the Manual that all the champion motors use the same damper with the exception of the timing marks !!!!!!
So after reading that it may well be the wrong damper fitted.
From a Truck maybe ???
Or an earlier Champion ?
I can`t believe the hub is not fully on due to the Woodruff key being kicked up as in pic 3 on my post #9 the dowels look to far into the ring meaning it can`t be kicked up,but it`s certainly possible for the crank bolt to be loose enough for the dowels not to protrude enough.
Altair,
As I understand the damper assembly it is sandwiched between the hub and the crank bolt,if the bolt was loose then the dowels may not protrude enough for the lock plate to locate
But the position of the Rotor/Dizzy or even the oil pump would not alter the damper position in regard to the crank shaft.
You can clearly see in post #9 that the #1 piston is at the top of it`s bore.
In that position the timing marks should be by the pointer regardless of where the valves are !!!
And they are not, the marks are the opposite bottom side of the motor.
I will pull the rad out and take the damper apart to investigate what is going on there.
But for a 65 year old motor anythings possible to make me pull my hair out !!! lol
Geoff
Altair,
Geoff
