I have a friend looking for a head for his R2 engine. I am going through my sets of heads and wanting to know which heads were specific to the R2 engines? Thanks. Bruce
R2 Head casting numbers
A simple Google search for " Studebaker V8 cylinder heads " will give you this http://studebaker-info.org/text3/Headcasting.html
Robert Kapteyn
1557582
And its nice that these are the same as most of the heads you'll find on 63 and 64 trucks. Cuz they're the low compression heads to compensate for the increase from the supercharger. So don't over pay just cuz they belong to an R2. They are more common that many folks know.sals54
Yes, to being used on trucks.
No, to being common any longer. Since a hard-used R2 will crack these thinner castings, they're getting scarce up here. FWIW, I built a set and sent them to France for one of the few R2s still extant there.
I've got only one pair on the shelf at present, versus many of the earlier and R1 castings.
EDIT - just sold these R2 heads in less 30 minutes of posting I had them. The R2 owner's heads were cracked beyond repair.
jack vinesLast edited by PackardV8; 05-06-2016, 02:51 PM.PackardV8
I do not believe the 1557582 was ever used on Trucks.
I show the 1557580 as the Jet Thrust Lark/Hawk Engine 9.0 to 1 Cyl. Head, but it is not a Truck Head as some people think.
It is just very similar to the Part Number 536097 > 7.5 to one Truck Head, or the export Truck Head 536790, either of which would work fine on R2 to produce about 9.0-9.5 Comp. with Flat Top Avanti Pistons for a Paxton equipped Engine. (Source: 1962 7E Truck Parts Catalog.)
These Heads used on trucks were also used back to '55 or '56 for Export Cars and many WERE in S/B stock at the Factory closing and well after, if the Australians have not gobbled them all up by now, there should be some still around.StudeRich
Originally posted by 63r2 View PostRich
582 heads are very common in Australia, you can't give them away.pb
Doesn't anyone UNDER there, run a Supercharger?StudeRich
Originally posted by StudeRich View PostOK, that 1557582 must be the Casting number for the 1557580 Part Number R2 Head.
Your friend may want to think about taking a 1557570 head (R1/289std) and cleaning up the chamber riding it of sharp edges and such.
It will not take long to go from 54cc to 67cc.
Afterwards you have a better running head that is less likely to crack as the 1557582 head. I'm running the 570s on my R2 Build.
