I finished stripping my block down (289) to take to the Machinist. I removed the plug and pressure relief spring, but I'm wondering if there's something else in there that needs to come out, like a cup or plunger. Thanks, guys...
Oil Pressure Relief Spring
Yes there's plunger in there. They are sometimes ornery to get out, do a forum search on the topic for advice on how to remove. I've had good luck with an easy-out gently tapped into the plunger and then a process of pushing and pulling it back and forth to pull it out of the bore. Recommend using a solvent such as carb cleaner to clean out the bore as there is likely some accumulated gunk in there.Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
After spraying with your favorite lubricant, the taper of a Pencil gently forced into the hole in the center will usually, but not always do the trick depending if it is gunked up badly or not.StudeRich
Originally posted by 345 DeSoto View PostI finished stripping my block down (289) to take to the Machinist. I removed the plug and pressure relief spring, but I'm wondering if there's something else in there that needs to come out, like a cup or plunger. Thanks, guys...
PaulI finally have a Stude I can drive! (sort of)
1962 GT Hawk, 4 speed, a/c
Tony,
You and your machinist are both aware of the pipe plug in the oil galley just under the distributor--yes?"All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
From Bob Johnstone's site.............
http://www.studebaker-info.org/text3...leryplugs.htmlAL SORAN RACING
ROCKNE10 - Got that one out, but the plug in the OTHER oil gallery on the opposite side won't budge...Last edited by 345 DeSoto; 05-04-2016, 12:46 PM.
