Is there a flow restrictor in the supply line to the spin on bypass filter? If so what is the size of the orifice? Is there a cover plate available to cover the oil filler hole in the block when I remove the original stand-up cast iron fill pipe?
Flow restricter bypass filter system
Ayn Rand: "You can avoid reality, but you cannot avoid the consequences of avoiding reality."
Originally posted by 345 DeSoto View PostWhere is the flow restrictor in the NON spin off Stock canister system?Somewhere in the pressure line going into the canister, or right where the pressure is taken from the engine. The location of the restrictor varied on those installations. It makes no difference where it is located just so long as it is somewhere before the pressurized "dirty" oil gets to the filter, not after it.
BP
The block-off plate is available from Studebaker International. Part #1555680. $8.50.BP
