1953 Commander dash color question
  • Interior: 1953 Commander dash color question
    The dash in my 1953 Commander is two different colors but from what I have read it should all be Loma Grey. Could this be an option or just some custom work when new? I would assume the pin stripping was indeed added on. As far as I know about the history of the car it is all original and it would have been a lot of work to take it out for painting. If it was done later then they did a good job as I don't see any overspray or any other indications.
    The main dash should be Loma Gray (on most cars). The area of the hooded instruments on Commanders was a darker color.
    As you assume, Studebaker did not do the pin striping.
    EDIT: The net is; the colors on your dash, excluding the pin stripes, appear correct.
      The gauge surrounds were, indeed, charcoal with gold under the hoods. The sheet metal dash in '53, at least in South Bend production, was the Loma Grey; along with window garnish moldings, steering column & shift lever, passenger interior vent door and a number of other little details.
      Here's a dead on formula for the Loma Grey.
Name:	Loma Grey paint.jpg
      Brad Johnson,
      '56 Sky Hawk in process
        The pin striping is also original. The backing should be natural aluminum with the decal type pinstriping. It is very fine and maybe dual or tripple? with a space, then repeating rows?
        Bez Auto Alchemy
          Well once again I appreciate the help! Now I can move forward with the interior. Thanks for that paint code too, that will make life easier for sure!
          Rich
            Bez, please elaborate on the pin striping being original. I don't recall ever seeing it before.
            Don Wilson, Centralia, WA
            40 Champion 4 door*
            50 Champion 2 door*
            53 Commander K Auto*
            53 Commander K overdrive*
            55 President Speedster
            62 GT 4Speed*
            63 Avanti R1*
            64 Champ 1/2 ton
            * Formerly owned
              The painted dash color for most, not all, 1953 C/K models was Loma Gray (GRAY).
              The exception was on Bombay Red cars trimed in Flax vinyl. These cars had Monterey Beige painted metal trim.
              That is why I qualified Loma Gray with "on most cars" in my post #2.
                My early 53 Tri-star had the exact same pin stripping on the metal gauge hood backing. The flat piece where the gold "V" is located.
                I'm not talking about the freehand embellishment on the edge pictured.
                Bez Auto Alchemy
                  Hello, I am in a similar position in researching my 53 Commander, Starliner for restoration.
                  I have an LA car, originally Monterey Beige over Coral Red (painted gray by previous owner 30 years ago). The interior is the Loma gray as discussed.
                  My question is in regards to the dash gauge hoods. The gray is a darker warm gray. Any reference to what that color is or is it something I need to have matched?
                  Also the underside it painted gold. Is this the same gold that was used on the wheel centers?
                  The photo referenced to the gauge cluster in the shop manual (body 6, fig 18 & 20) shows the underside of the gauge hoods and they look very shiny (almost reflective).
                  Mine are still gold but very dull.
                  One more thing since I am thinking of dash related issues:
                  the ashtrays. the one in the dash is pretty corroded inside but the rear one is in nice shape. The rear one looks original and has a grayish color finish inside and out, like zinc or something.
                  Any idea what that is and how I can restore them both to original?
                  Thanks in advance for the feedback!
                    On my 1950 ashtray, which had some rust, I sandblasted the tray part, then plated it with the Caswell "Copy-Cad" home plating kit. It came out nice, and is actually a zinc plating. I still need to match the dash paint so I can repaint the front of it, as it has a few light scratches.
                      This picture is of a NOS '53 Commander dash instrument plate showing the pattern Bez is describing.
                        Where did you find an NOS dash instrument plate? Do you have more than one? interested in selling?
                        Any help restoring mine?
                        I am trying to find someone who will restore mine and most dash resto places won't even bid it.
                        One guy who finally did gave me a crazy high price and said he couldn't guarantee it would even look correct.
                        Thanks in advance for any help you can provide.
                          At one point, I fabricated the pin striping on my dash, I first drew the entire dash in AutoCad, put the striping on, Spray painted a couple of sheets of paper silver and printed the striping on the silver paper. It surprised a lot of folks that it was paper, until the humidity got it, and the paper swelled. Bye the way, that piece of metal can be either aluminum or steel. That's why I had to print mine, the aluminum was banged up from in and out, I got a replacement that was steel, rusted. Printed paper did the trick.
                            Year-old thread.
                            Skip Lackie
                              I think I found that one in a dealer's stock that I bought out back in the '70s. It was for my '53 Commander Starliner. I never saw another.
                              When I first did a poor amateur restoration in my '53, it was a daily driver. I had a Navy draftsman who rode with me to and from work (no charge, no obligation). I showed him my pretty rough dash mat and he said I can make that like new. I painted it silver and he used his drafting equipment to line it. Couldn't tell it from new.
