Hi Brad, yes thay are studie people here that have told me the things to do,i was at the studie int. i have been in the sdc for 40 + yrs, but i just thought i could here from the forum more ideas to never hurts to talk to others ? i have to many cars to put a ton in one , trying to just get it as a driver if it smokes no big deal most of the studies i have had smoke , later.
to un stick a engine ????
Fred, to reply to your responce , i know a little about this car it sat all that time cause & may be longer the guy died that had a lot of cars he bought cars for 35 yrs, never done any of them, so never know i might have got lucky on this one or not , i know that being a 62 daytona v8 4 speed it will sell cause of what it is good shape, i have time to let it soke in fluid some more thanks for your in put thow .
penetrant
Originally posted by dannyo View PostJeffry, i just sent you a personal massage, what is Breakaway some name brand pennatrate ? dannyo.
Originally posted by rockne10 View PostI can't imagine there aren't folks around Springfield who are familiar with Studebakers. The SDC International Meet was held there just three years ago.
I ruined the camshaft on a 1928 Erskine (Continental 9F engine) trying to crank it over with a big breaker bar. The oil pump has seized (unknown to me at the time) and when the engine finally turned it stripped the oil pump drive gear on the camshaft. Try locating a camshaft for 1928 Erskine, it took me two years in the days before the internet. Took a lot of letter writing and waiting for replies via snail mail.Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
hi Richard , saw your reply to my problem on this 62 lark, REAL MECHANIC, they are all gone like Lester schmitt, he was a real mech, know him for 20 yrs , died at 87, most young guys dont even know what a studebaker is, & dont care dont want to put a ton of money in a car that is only worth 3,000.00 if it ran any way , larks dont bring that much i would be up side down , at 100.00 per hour to do any kind of over hall or 3,000.00 + to build a engine no wander people put chevy crate motors in, i am to old to even put 1 in or take out ? kroil i have tryed it on other studies cost high did not work eather , guess we will leave i at that .
Proper use of High Explosives will unstick anything!
keep on dumpin in the atf/acetone mix pull the lifters if you can. Fill the pan with diesel fuel.
Let her sit for a month, take a prybar and stick it in the starter hole (after removing the starter of course) and pry back and forth a little at a time.
if it moves and inch, eventually it'll move a mile. patience is key.
Kroil is not a miracle solution. I bought a gallon of the stuff several years ago, due to all the raving here about its miraculous abilities. It is no better or worse than off the shelf stuff at FLAPS.
As for un-sticking that motor. Even if you get it un-stuck, it is in no condition to be placed into service, without a tear down and repair/replacement of parts as necessary. I once fired up a 352 motor in a 56J that was not even stuck; it had simply been sitting for 20 years. I did more damage in 5 minutes of running it than the 20 years' sitting had done to it. Never again.
yes, fred i still will try to turn it for a while with the acetone& atf in it , pull the valve covers hit on the valves with rubber hamer , see thay are stuck ?? you never know, i have so many iron s in the fire at 67 yrs old, it wont get worth less . got a running engine in a 62 junk cruser, if nothing else may be i can offer some one 100.00 to swap for me , once it is out a friend of mine can put it on a engine stand he likes to take apart engines , just hanging on because it is a 4 speed , later dannyo.
I'm with a few others here.
I've unstuck my share of motors but they hadn't been seized up for a quarter of a century. Even if you can get the piston's unstuck and everything else seems to be unstuck - no hung valves, no frozen wrist pins etc. it's still a question of whether or not those rings - especially the oil rings - will, after soaking, be able to move freely in their lands or are going to allow those pistons to slap like crazy. What about mounds of rust built up on valve seats where valves were in the open position? If the oil in the oil galleries has congealed, when you start it will fresh oil flow to the places it needs to flow or will you be stressing it more by running it without good oil flow?
These are not complicated engines to tear down and rebuild.Mike O'Handley, Cat Herder Third Class
Kenmore, Washington
hausdok@msn.com
'58 Packard Hawk
'05 Subaru Baja Turbo
'71 Toyota Crown Coupe
'69 Pontiac Firebird
(What is it with me and discontinued/orphan cars?)
Mike, i know you are probly right i just dont have the place to do it + dont like engine work at all, transmissions , rear ends, i went to school way back, speclized in , tune ups, brakes, carb s, also body work fair, paint good, engines not my thing to much to take in have done , might put up for sale later for 6,000.00 fair price for what it is , let some one else do it, we will see .
I think you are a little high on how much a non-running project car will bring. For non-collector cars, I have found that Collector Car Market Review is pretty close to what the market will bear http://www.collectorcarmarket.com/co...ona-value.html. If the car is in good shape overall, it would be worth your while to get it running.78 Avanti RQB 2792
64 Avanti R1 R5408
63 Avanti R1 R4551
63 Avanti R1 R2281
62 GT Hawk V15949
56 GH 6032504
56 GH 6032588
55 Speedster 7160047
55 Speedster 7165279
