I am going to change my filter etc in my Flightomatic transmission for my 61 Lark six cylinder, What transmission fluid do I use and how much? I forgot what I used last time. Thanks.
Fluid
Tags: None
If the transmission is original, then type F. If it has been rebuilt with other than the original clutches, (which were brass), then Dexron II or better.Bez Auto Alchemy
I agree any will do, but prefer not to mix types or brands. However, I cannot say I have not mixed. I have not really noticed any difference in topping off with whatever is available. But Type 'F' causes them to shift a bit more aggressively.
Originally posted by 1954khardtop View Postbezhawk, I had my '56 flight-o-matic transmission rebuilt about 2,000 miles ago, using paper clutches. I am using type F, will this cause problems? Should I change it to Dexron? ThanksBez Auto Alchemy
Type "F" or "FA" is still made by Valvoline, ask your NAPA, Carquest (or is it Advance now?) Store for it, if not in stock it CAN be ordered and in by Tomorrow.
Most of these Flight-O-Matics are so strong and dependable that they are STILL running on the Original Brass and Asbestos Clutch Discs unless you know yours is otherwise, the Type "F" is still the Best performing ATF.StudeRich
