I have a '63 Hawk, Grand Tourismo with a stuck shifter. I had this car up and running before I put it away for the winter. When my buddies took it out of the barn, the shifter got stuck. Any clue as how to proceed? Some say I need to replace the whole steering column. I would appreciate sound advice as how to get it in gear.
Shiftless in Wisconsin
Tags: None
If an auto you can jam one in park by keeping pressure on park pawl so it wont release, like parking on slope. if manual "3 on the tree" have someone hold brake and clutch down, you get under the hood and manually move shifter arms on column to neutral its hung up. once sorted out look at shift mechanism inside column. Luck, Doofus
I had a 54 Chevy that did the same thing. I'd lift the hood and move each lever on the steering column to the neutral position, then drive the car, but be careful to use a strict H pattern, rather than try to slide through in an X pattern.
In other words you pull the lever towards you lightly as you move it up to the neutral position, then move the lever straight forward, then lift it up to second gear.
Look at motor mounts as well. Deteriorated or separated mounts can generate shifting problems. Usually a jam occurs when the column shifter tube drops into the 2/3 lever before the trans comes out of 1st gear. The detent interlock in the trans will not allow the 2/3 lever to move because 1st is still not completely disengaged but the selector in the column is no longer engaged in the 1st/reverse lever. While holding the clutch and brake, have an assistant pull up on the 1st/reverse lever to the neutral position and it will shift again. The short term cure is new lever bushings, proper adjustment, and good mounts. If the shift tube in the column is worn, it may have to be replaced.james r pepper
Still no answer from Studious. I would guess it is stick and the shifter is jambed between the levers in the column, but then it would be stuck in one gear ... usually. From his post it is in no gear. Curious........sigpic
Claude Chmielewski
Studeski
http://www.studeski.com
Fillmore, Wisconsin
47 M-16 Truck
53 Commander Regal HT
53 2R5
60 Lark VIII Convertible
60 5E7 Champ pickup
62 5E7 Champ no box
62 GT Hawk 4 speed
63 Lark VI parts car
63 GT Hawk R2 4 speed
64 Commander Wagonaire
64 Daytona Convertible
50 Champion Regal (parts car)
36 Dictator
36 Dictator in pieces
