My brothers 62 Lark Convertible V-8 automatic is in the shop with a transmission fluid leakage issue (go figure). The mechanic discovered that the transmission fluid dip stick has a cracked metal cap, where it slips over the filler tube. He feels that transmission fluid is coming out the end of the tube when the car is driven because of the cracked cap. Does this seem reasonable, can the transmission fluid get high enough in the system to come out of the long filler tube?
Auto Dip Stick Leakage Question
Transmission / Overdrive: Auto Dip Stick Leakage Question
Dan Peterson
Montpelier, VT
1960 Lark V-8 Convertible
1960 Lark V-8 Convertible (parts car)Tags: None
The tube only has a single flare and it can crack causing a leak. If the flare is cracked, there isn't many places that can reflare a tube that large. You may try an air compressor repair place, as the cylinder intercoolers are about that diameter of tube, and they may be able to reflare the tube. If not, you need to replace it.Bez Auto Alchemy
Originally posted by dpson View PostMy brothers 62 Lark Convertible V-8 automatic is in the shop with a transmission fluid leakage issue (go figure). The mechanic discovered that the transmission fluid dip stick has a cracked metal cap, where it slips over the filler tube. He feels that transmission fluid is coming out the end of the tube when the car is driven because of the cracked cap. Does this seem reasonable, can the transmission fluid get high enough in the system to come out of the long filler tube?
Thanks for the suggestions. As mentioned it likely not the dip stick that's causing the leakage, but rather the tube where it enters the pan. I'll pass this along to my brother.Dan Peterson
Montpelier, VT
For what its worth, if the leak is out the top of the dipstick tube, it seems likely that it would be due to high pressure inside the tranny?
If that's the case, you ought to check to see if the tranny vent is clear, or at least that the cap can be jiggled around.
Its a kinda mini-soda cap affair loosely sweged over a port on the upper right side of the trans.
If the trans is in the car, you'd probably have to find the vent by touch from underneath the car.
I'll put it this way: if the info has been passed along correctly to you from the Shop Tech to your Brother to you and to us, there is NO WAY a Dipstick Cap could cause that.StudeRich
