White stuff in the battery tray
  • Hallabutt
    Use an Optima battery and problem will go away!
  • Lynn
    Used to be the really good quality batteries rarely had issues as long as they were not being overcharged, and were maintained properly.
    Seems about 15 years ago, I couldn't find a battery that didn't either leak or corrode way too fast. Yes, there are some band aids. The mat helps. The green and red rings help if saturated in something that neutralizes battery acid. Most of the time, I just use an Optima when possible. You could mount it upside down, and it won't leak or corrode. I have seen multiple posts in the last couple years complaining about the Optima quality has gone down hill drastically. I have several in service, and just put one in a car a few weeks ago. Fortunately, I have not had any issues with them. No more "fungus garden".
  • Michidan
    Thanks all. Working on getting it fixed up.
  • T.J lavallee
    Don't forget to clean your battery tray with baking soda dissolved in a small amount of water in a bowl and a small scrub brush. Wipe the area dry with paper towels after.
  • 53commander
    Originally posted by Lynn View Post
    IMHO 15v is too high. 13.8 to 14.2 is what you want with no load.
    I agree with this, even a higher amp alternator should limit the charging voltage.
  • Skip Lackie
    Originally posted by doofus View Post
    According to a reputed batt rep this is caused by gasses leaking around the batt posts. look for color coded, treated felt washers at your flaps, they have helped. Luck Doofus
    Yes -- what doofus said. The white powder on the battery post is lead sulfate (mixed in with a bit of sulfuric acid), and is created by the hydrogen gas that is created when the battery is charging (especially when it is overcharging) pushing tiny droplets of sulfuric acid out of the battery, where it reacts with the lead posts. If it's blue-green, it has some copper sulfate in it too. If it's on the battery tray, it's iron sulfate. The GM side post batteries were supposedly designed to reduce this problem, though they created other problems of their own (they're hard to jump). Any FLAPS will have the felt washers (treated with something alkaline and a bit of oil) that should reduce the generation of the powder.
  • Lynn
  • doofus
  • Michidan
    That seems likely. What can you tell me about it ...what's normal? Voltmeter always sits around 15 V running. I put a 94 amp alternator on it thinking I would run an electric fan, which I do not. In fact I run basically no electric accessories at all. Car doesn't even have a radio.
  • sweetolbob
    Check alternator output and voltage regulator to be sure it isn't over charging.
  • Michidan
    To fit in the big motor my battery try is homemade and in the rear passenger corner of the engine compartment. I designed it to hold the battery down by the bottom ridges. (and we all know how important a battery hold down is.) But because of this I have a height limit for putting in a pad of some sort.
    I have a thin sheet of plastic down already but it was not helping.
  • TWChamp
    Some MoPars in the 80's had shallow battery trays under the battery. I pick them up at junk yards and use them to save the metal from corrosion. Overcharging can lead to acid bubbling out the caps. I smear Vaseline or grease around the battery posts to help prevent corrosion.
  • warrlaw1
    That's pretty common. S.I. sells a pad that goes under the battery and is supposed to neutralize that stuff so it doesn't corrode the tray and inner fender. I have one on mine and the corrosion has been minimal. Good luck, Dan.
  • Michidan
    started a topic Electrical: White stuff in the battery tray
    The last few years I've been getting a lot of corrosion in the battery tray. The same white by-product you would see from really old AA batteries. I suppose it means the battery has a leak, but it sure doesn't look like it.
    I'm replacing the battery and cables this week. But while I'm at it, would there be any other cause, a problem with the wiring or a drain, that would lead to this kind of problem?
