On a 289 engine without super charge. The timing is suppose to be set at 4deg. before top dead center. I cannot see where there is any marks to tell me the diff. degrees. What do I do now or am I not seeing the marks.?
Timing question
There is usually a mark that says "ign." That's the one to use.RadioRoy, specializing in AM/FM conversions with auxiliary inputs for iPod/satellite/CD player. In the old car radio business since 1985.
60V-L6 - 60 Lark convertible
What jackb said...
The performance and mileage will be noticeably better with increased ignition over the "book" values. There's many ways of doing this, experimentation is the key to success.
8 to 10 degrees on the damper is a good place to be.
I took my damper wheel off and marked every (2) degrees, not that difficult.
Or,you can use a vacuum gauge and turn the distributor until you are drawing the maximum inches and you will feel or hear the "sweet spot" when the engine hits it. The book settings don't always give the engine what it wants.
I fail to understand the reasoning of some people posting here that feel they know more than the engineers that designed the Studebaker engines. Advancing the spark a few degrees is probably not going to hurt anything, but arbitrarily twisting the distributor without using a timing light is asking for detonation at high engine speed when it can't be heard. Again, I recommend that anyone that uses a vacuum gauge for setting the timing or tuning by ear, please read Jim Pepper's excellent article on Studebaker ignition timing in the September 2014 issue of Turning Wheels. Use a timing light for setting the ignition timing, that is why they were invented. Bud
