Where do I find the carburetor ID number in my WCFB carburetor?
Wcfb 2219s
WCFB ID tag
The '2219S' you are looking for appears on the triangular brass tag the is/was attached to the rear corner driver's side of the carb with the screw that holds the air horn to the body/bowls of the carb.There is a guy on Ebay who sells these tags and will imprint any code you want on them. This is him. http://www.ebay.com/itm/251739819490...%3AMEBIDX%3AIT You will need to tell him the date your '55 was built do he can put the right date code on it.
I think there are casting numbers in the back of the carb, nearest the firewall. I had to use a mirror to find any numbers on mine. Mine is also from a 55 Champion (or Commander) I bought a rebuild kit thru Studebaker International and it is universal, as it has every gasket needed and some you don't.Dis-Use on a Car is Worse Than Mis-Use...
1959 Studebaker Lark VIII 2DHTP
Some sources say the model number is stamped under carb. base.
This list of air horn casting nos. may help identify the carb. model. The no. on mine is stamped inside a circle at left rear of carb top, and it does correspond to the tag no.
https://www.carburetor-parts.com/Car...al_ep_313.htmlAL SORAN RACING
Originally posted by 345 DeSoto View PostWell, barring any other way to Identify it, I guess I'm going to have to tear it down and check each and every part number...
Wouldn't it likely be the correct model shown in the '55-'58 Chassis Parts Catalog for a 1956 Stude. ?StudeRich
Originally posted by altair View PostI have two early aluminum four barrels (Carters) and one has the ident number stamped on the base close to the fire wall and the other has the ident stamped on the base close to the radiator.
They learned on Newer Carbs, that the Tags used on the WCFB's got lost.StudeRich
Originally posted by colt45sa View PostWere you looking for us to give you all the numbers from a '2219S'. I can help you with the number off the top of the air horn. I'll have to dig one out if so.
