I am going to have to replace it with a higher gear, so was just trying to figure out what I had to start out with. The tag that said 45B was all I could find at first, but will double check tomorrow and see if I can find another tag somewhere. I have enough power for even a 256 or around there. Richard
TT Rear Axle
45B just means it's a Twin Traction. There should be another tag on there, either with the ratio or something like 41/11 which would be the tooth ratio of ring to pinion (in my example, a 3.73:1 ratio) if the other tag is missing you will have to either count the teeth or else have a helper count revs for you.
good luck,
http://home.comcast.net/~njnagel--
good luck,
Like someone else said, he could also pull the cover and look for the numbers stamped into the side of the ring gear.
5E13
7E7
8E7
8E12
8E28
4E2
59 Lark
etc
http://www.ringpinion.com/content/calculators/RPM.asp
Onthis page you will find several calculators.
The ring gear has 41 teeth
the pinion gear has 11 teeth
41 divided by 11 = 3.727272, , rounded off to
3.73
5E13
7E7
8E7
8E12
8E28
4E2
59 Lark
etc
I took my time and wiped everything real clean and the tag says it is 43/14 and below that says 3.07 So divide 14 into 43 and it comes out 3.07. So now I know for sure what it is. Thanks to you guys I have finally figured out what gear ratio I have in my Hawk. Again Thanks guys. Richard
If your differential actually has 3.07 gears in it you should be getting better gas milage. Do you have a tachometer and if so what rpm are you running at 60mph. I would guess that you just need to spend some time tuning your engine.
David
Sure, you never said what's under the hood except GM, it could be a SB 400 with a 750 CFM carb.! Or the axle ratio tag may lie[:0] anything is possible! Either of which would account for the poor mileage, even an incorrect speedo, with an engine swap, that's a good possibility.
David
Studebakers Northwest
Ferndale, WAStudeRich
Got to get me a tach, but I didn't know this, but after driving 400 miles to pick the car up, I asked what is with this motor, and the seller said, It's bored 40, a 5/8 cam, and 600 holley, but the car was in such good shape I took it anyway. Fast little car, but it was 100 degrees outside on the trip I took, and ran A/C all the way, so I guess I shouldn't grip.
