power steering
hey guys this is a up date,i received the power steering cover and fill cap,i installed it and works beautifully and now it is easy to check the power steering fluid. thanks for the tip. leonard
I ordered the power steering pump top,the filler cap and gaskets,i guessed at the diameter of the top at 4 3/4 , if it is 2 small I'm sure a parts store will have the right size. I only hop that gets here before the thermostat gets here. I want to put it before I fill the cooling system, I figured the thermostat was my problem with empted my radiator. must have had another senior moment. leonard
Originally posted by rkapteyn View PostIf you install a Ford power steering pump lid , you and check the level much easier
Ford used the same Eaton power steering pump but it has a fill cap.
http://www.macsautoparts.com/ford_th...1&y=8&cat=2511
Robert Kapteyn
Yep and NPD, CJ Pony and others have them also. If you look through the different Ford applications you can even find one with a "filler neck" if you have room to clear it. They all are the same diameter, and the hold down post is the same.
are you sure this will fit my power steering pump top? 64 cruiser 289 v/8. thank you.
Robert Kapteyn
Robert Kapteyn
thank you doofus,what type of power steering fluid do you recommend? again thank you leonard.
I had the same problem, remove lid bolt and slide lid sideways while holding hose up slightly. luck Doofus
power steering
how do I check the level of my power steering fluid? I see the container but the radiator hose is mounted on the top of the fluid container. this a 64 cruiser 289 v/8. thanks in advance.Tags: None
