I have inherited a 1950 Commander 6 cyl and need a carb. The manual calls for a Stromberg BXOV-26. In searching for one I see them for many different models. My car is a 17A. Are they that unique or will most BXOV-26 carbs interchange. I'm new owner looking to get running so thanks for any detail that could be explained.
Stromberg carb
Tags: None
The Stromberg BXOV-26's for other Makes most likely have different Linkage connections and Locations, so if they are for Studebakers, most years should work fine.StudeRich
This carb was also used on some Studebaker trucks but these where set up for manual choke instead of automatic choke like your car is. 50 commanders are fun and unique cars which should provide you with lots of fun times
these carbs are not the easiest to find but are available. Some 17a cars were also equipped with carter we carbs based on serial numbers. These carbs are easier to find I prefer the stromberg as I have had both.
One of of our vendors Dave Thibault in Mass. Does a great job of rebuilding both the carbs and fuel pumps on these carsMilt
1961 Hawk 4-speed
1967 Avanti
1961 Lark 2 door
1988 Avanti Convertible
Member of SDC since 1973
And Dave often has rebuilt carbs on the shelf, ready to ship. Worth checking."All attempts to 'rise above the issue' are simply an excuse to avoid it profitably." --Dick Gregory
'33 Rockne 10,
'51 Commander Starlight,
'56 Sky Hawk
Originally posted by unclemiltie View PostThis carb was also used on some Studebaker trucks but these where set up for manual choke instead of automatic choke like your car is. 50 commanders are fun and unique cars which should provide you with lots of fun times
Follow the link--suggest calling before 4PM EDT http://www.studebaker-info.org/vendo...tbow0513b.html
