Bezhawk - lol
Bolt On Crankshaft Socket
Originally posted by Mrs K Corbin View PostI'm going to ask a dumb question: Are you sure the tranny isn't holding you back somehow? I'm a little confused on the whole "Every time I hit the remote start, the tip of the fan moves forward about a 1/16 of an inch or so, then moves back to where it was." The fan shouldn't move at all if the engine is actually stuck.....
I'm thinking pull the starter and rock that engine back and forth with a prybar on the flywheel teeth..... Make sure the tranny is not what's stuck as well...
OR there isn't a critter home in the bell-housing......Gord Richmond, within Weasel range of the Alberta Badlands
Originally posted by JoeHall View PostA self proclaimed flipper here used to brag about getting pistons unstuck with Kroil, a block of wood and a BFH. He did not drive them, just flipped them.
If you get yours broke loose, you can flip it too
Originally posted by gordr View PostSounds to me like one or more pistons are stuck. The crank will move a tiny amount as force form the starter takes up the clearance in the main and rod bearings.
then try bumping it again. it just might be a stuck valve you're dealing with and if it's stuck you could end up with a hole in a piston if it hits.l
I'll cut a wood block and start on the 5 non-leaking pistons...
jack vinesPackardV8
