I've just made my own remote starter to aid in the installation of my 60' 259 V8 distributor so as to bump the motor over so I can seat the shaft into the oil pump as was suggested to me by many forum contributors . It's a simple two post push button switch. I only get to work on my project one day a week so it's slow going. I'm waiting for springs and weights from S.I. before I go on with the installation just to be on the sure side. My question is do I simply connect my two clamps to the solenoid or "Magnetic Switch" as the manual refers to it (Red to the hot post-Black to the post that feeds directly to the starter) so as to bypass the magnetic switch as if I'm checking for a faulty magnetic switch as the manual prescribes or am I barking up the wrong tree? I don't want to guess at it and cause any damage. Thanks in advance.
bump start
If you mean putting your homemade switch across both LARGE terminals,no you will instantly let all the smoke out of your wire and switch.[and burn your fingers] Hook up your temporary switch to the hot post[from battery] and to the small post[whichever small post gets activated by the ignition 'start' switch.Now push your homemade switch to crank starter. If you want to bypass the "magnetic switch" you'd want to use jumper cables-red to hot and the other end of 'red' to the cable to starter. [expect sparks]
I have in a hurry,used a large pair of pliers to jump the two large terminals.[one handle of pliers on each large terminal]
[I'm assuming you used wire quite a lot smaller than a battery cable to make your remote start switch]Oglesby,Il.
http://www.macsautoparts.com/ford_me...passenger.html
I am not sure if this one is wired correctly, or has the right mount for studebakers, but I went to my local starter shop and they got one for me. I have on on my 54 champion.54 Champion coupe
48 Champion Convert
Originally posted by 52hawk View PostIf you mean putting your homemade switch across both LARGE terminals,no you will instantly let all the smoke out of your wire and switch.[and burn your fingers] Hook up your temporary switch to the hot post[from battery] and to the small post[whichever small post gets activated by the ignition 'start' switch.Now push your homemade switch to crank starter. If you want to bypass the "magnetic switch" you'd want to use jumper cables-red to hot and the other end of 'red' to the cable to starter. [expect sparks]
Amazon has a bunch of remote starter switches available for under $20 which would be the right tool to use to bypass the ignition switch. A remote starter switch gets connected to the hot battery terminal and the S terminal on the starter solenoid which bypasses the ignition switch for cranking the engine. Keep in mind that the engine could start if the distributor is on the engine and connected as the starter solenoid on 12 volt V8 Studebakers also has an ignition ballast resistor bypass in it to aid in faster starting which works even though the ignition key is in the off position. Bud
Originally posted by Bud View PostAmazon has a bunch of remote starter switches available for under $20 which would be the right tool to use to bypass the ignition switch. A remote starter switch gets connected to the hot battery terminal and the S terminal on the starter solenoid which bypasses the ignition switch for cranking the engine. Keep in mind that the engine could start if the distributor is on the engine and connected as the starter solenoid on 12 volt V8 Studebakers also has an ignition ballast resistor bypass in it to aid in faster starting which works even though the ignition key is in the off position. Bud
And make sure it is out of gear (with the wheels chocked)
No surprises!
Originally posted by Bud View PostA remote starter switch can be used anytime you need to crank the engine while doing maintenance. Just be sure that the ignition is disabled or the engine can start when you least expect it. BudHTIH (Hope The Info Helps)
