Originally posted by greyben
View Post
Generator question for the old school guys
"Spilling a beer is the adult equivalent of a kid letting go of a Balloon."
RE The engine running without a battery. My former brother-in-law and some high school friends bought an old military jeep to go into the hills, but they could not afford a battery. He told me they just tied the battery cables together and always parked on a hill so they could roll start the jeep."In the heart of Arkansas."
In your two photos, the regulator wires appear correct. At the generator I think I can actually see a letter 'A' stamped into the case at the upper terminal. That terminal should hold the white wire.
Charging rate as shown on the ammeter is inversely proportional to battery state of charge.AL SORAN RACING
Originally posted by Dwain G. View PostIn your two photos, the regulator wires appear correct. At the generator I think I can actually see a letter 'A' stamped into the case at the upper terminal. That terminal should hold the white wire.
Thanks for your input!
You may have corrected the polarity, but your regulator may eventually may fail if you don't polarize the system.
I run generators when originally equipped and they all run with the battery disconnected when working properly.
Diodes will fry if you try the battery trick with an alternator setup. Especially if you rev the engine high.
Old mechanic here. Tying the two battery cables together would do nothing but fry the generator once the engine started, which I doubt it would with the + grounded. Was told in school that a car with alternator would shut down if the battery cable is unhooked. Surprise, if the car has a lot of miles on it, there is induced magnetism in the alternator and the car stays running. To get two of them to shut down, had to disconnect the big wire from the alternator, with it running, one does this very carefully.
If you remove the band on the generator you should see that the one terminal is connected to a brush holder. That is the armature terminal. The other terminal should be connected to a wire coming from one of the field coils. The field wire should also be a smaller gauge then the armature wire.
if the drawing that I have is correct (it is of an old Delco regulator) the armature wire goes to the center terminal. Most if not all Delco generators ground the field terminal through the regulator. With the engine running disconnection the field wire on the generator and connecting it to ground for a few seconds should cause the generator to go to full output.
Ron
An alternator needs electricity to excite the windings, but once it's working you can disconnect the battery and the engine should keep running. This isn't a good idea to leave it unhooked from the battery, but we did it a lot at the junk yards to check for a good working alternator.
I restored a generator I bought from French Lake Auto Parts for my 1950 Champion, and now it charges at idle. With the rebuilt generator that the seller just installed in the car, the generator wouldn't start charging until the engine reached about 800 RPM.
It isn't a good idea to just switch wires to see what happens, as it could very well burn out the generator, regulator, and wires.
Once a battery is charged up, the ammeter should be just barely on the charge side of zero. If it stays on 5 to 10 amps, or even more, you will cook the water out of the battery and could also buckle the plates from overcharging.
