Help! searching for a pinion gear (and how to put it on my cable)
  • Speedo / Tach / Gauges: Help! searching for a pinion gear (and how to put it on my cable)
    According to the parts book I would be happy with either a 520088 (16 teeth) or 520087 (15 teeth) so I can get my Scotsman cyclops reading the miles as they go by. (found it at Studebakers West)
    Since I've never replaced any speedo cable gear that looks like this, some helpful advice on the changeover would be much appreciated.
    JohnP, driving & reviving
    60 Lark & 58 Scotsman 4dr
    Sorry, checked my inventory and came with neither of the above.
    Dan Peterson
    Montpelier, VT
    1960 Lark V-8 Convertible
      From my experience, you remove the cap screw that holds the speedo cable in to the transmission tail, pull it out, pull the existing pinion off the cable and insert the new pinion. Insert in to the transmission tail and install the cap screw. Others may have different experience. Make note of your existing pinion number, as others may be in need of same.
      I see the 15 tooth 520087 on Ebay at this moment. http://www.ebay.com/itm/Studebaker-Speedometer-Pinion-Gear-520087-15-Teeth-1947-54-Cars-Trucks-/161992144964?hash=item25b77bf844:g:XY8AAOSwuYVWo96h&vxp=mtr
      '33 Rockne 10,
      '51 Commander Starlight,
      '56 Sky Hawk
        thanks for the info! I already had a new core just in case, but when I pulled the cable end out of the transmission I saw the pinion gear was missing half its teeth. I ordered a new one and I hope it is right. I'll know when I get the new engine put together with this trans and get it all back into the car.
