OAT, IAT, HOAT,POAT? antifreeze
  • Cool/Heat: OAT, IAT, HOAT,POAT? antifreeze
    Not as prevalent as the "What oil should I use?" but what coolant should I use? iron, aluminum, brass, copper. solder, gaskets... all seem to play a role.
    In general, what coolant type is suitable for a Studebaker?
    Ron Dame
    '63 Champ
    Good, old-fashioned ethylene-glycol green stuff....while you can still get it.
    'Most every Farm & Fleet, Tractor Supply-type place has it. Menards, too. BP
    Ayn Rand:
      O'Reilly's still carry the straight Antifreeze to Mix with water, and it's regular green old style, I paid 12.99 and got some Gallons of Distilled water to Mix with it.
      They hide it on the back of the Rack with the ripoff, 50% Water stuff in Front, twice the PROFIT!
      OAT, IAT, HOAT, POAT? Sounds like something to put into or come out of HORSES!
        http://www.motosport.com/product?psr...FZeEaQodbmUNyA
        This will last years, and not even require a pressurized system. It doesn't boil (under normal usage) Won't turn acidic.
        Bez Auto Alchemy
          I use Sierra, Napa has it.
            Evans Coolant is THE best, however don't even THINK about just draining and Pouring it in!
            Be sure to get the detailed, complicated, procedure to install this special replacement Coolant for Anti-Freeze.
            Part of it is: replace the Cap with a Evans Cap, Plug the Water Manifold Bleed Hole, Boil and steam the entire Engine, Radiator and Heater Core completely DRY, no moisture can be in the System.
              Right you are Rich. I just take it for granted that people can read. (directions on the container)
              Bez Auto Alchemy
                Rich, what do you mean by plugging the water manifold bleed hole?
                Paul
                Winston-Salem, NC
                  Why would you use anything other than the extended life stuff as found in all new cars? It's based on propylene glycol, less toxic and is good for many, many years.
                  My Caddy came with it from the factory with it, and when I replaced the water pump after 15 years, everything I could see was spotless and corrosion free.
                    The Studebaker V8's have a small hole at the bottom of the Thermostat Area of the Water Manifold under the Thermostat, to Bi-pass the Stat. if stuck closed, for some reason Evans wants it plugged.
                      I note they don't have a recommendation for cars. Why would that be?
                      • Waterless Coolant for: MX bikes, trail bikes, enduro bikes, street bikes, quad bikes, ATVs, UTVs and snowmobiles.
                      Don Wilson, Centralia, WA
                      40 Champion 4 door*
                      50 Champion 2 door*
                      53 Commander K Auto*
                      53 Commander K overdrive*
                      55 President Speedster
                      62 GT 4Speed*
                      63 Avanti R1*
                      64 Champ 1/2 ton
                      * Formerly owned
                        That's my question as well. You can get Sierra which is propylene glycol based, but it is green as well, and like most green coolant, should be changed every two years rather than 5 years for red/pink/purple/yellow coolants.
                        Ron Dame
                        '63 Champ
                          That's just one company offering Evans coolant. It is the first thing that popped up on google. If you really are interested in the product, go directly to Evans website.
                          Bez Auto Alchemy
                            Ah, gotcha, know exactly what you are referring to......my mind just needed a jumpstart.
                            Paul
                            Winston-Salem, NC
                              Huummmmm. Evans is ethylene glycol, 67%, a trace of propylene glycol, 2% corrosion inhibitors, balance (about 30%) water.
                              http://contrails.free.fr/temp/NPG+_MSDS.PDF
                              Why on earth would you pay $28 for that when you can buy Zerex (or any other brand) which is 90% ethylene glycol with inhibitors? Just add some water to Zerex, and presto, the same thing as Evans.
                              http://complyplus.grainger.com/grain...d=3822589#sec2
